Farmall Tractors Discussion Board
Re: 806 PTO will not engage
Posted by Milan H. Dilworth on May 23, 1999 at 22:52:09 from (209.161.38.166):
In Reply to: 806 PTO will not engage posted by david on May 20, 1999 at 07:13:14:
You can easily determine if the small pin in the control value is broken, by taking the plug out below the valve and see if the bottom spring and rod come out, or take out the upper seal base plug and see if you can pull the upper valve on out. I'd strongly suggest installing a piece of wire from an old choke cable in place of the small pin. In 20+ years I've never had the problem repeat itself. The wire is strong and not too brittle like the pin. First put the wire in a shop vise and hit it with a small hammer to bend a 90 deg in the end. Then put the wire in place and snip it off 1/8" ext. Use your hammer and bend the 2nd 90 deg. Then take it to a grinder and smooth up the ends to prevent any over extension.
Post a Followup
: Re: Re: 806 PTO will not engage
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
