Farmall Tractors Discussion Board
Re: Another charging followup. Found the culprit
Posted by Len on May 24, 1999 at 07:44:57 from (207.225.86.233):
In Reply to: Another charging followup. Found the culprit posted by The Red on May 22, 1999 at 09:06:12:
Sounds like you adjusted the output voltage. It would be a good idea to take a volt meter and check voltage while charging. If over 15, it'll cook your battery. 14.5 volts is a better upper limit if you run for more than a few minutes at a time.
Post a Followup
: Re: Re: Another charging followup. Found the culprit
