Farmall Tractors Discussion Board
Farmall 200 Engine Speed
Posted by Les on May 24, 1999 at 15:41:10 from (198.247.207.252):
Have just acquired a Farmall 200 in excellent shape. Only one problem. After running the engine for 15-20 min. it tends to race at idle and in fact races so much that it will diesel when you turn off the ignition. Any suggestions on where to look first. Again, the problem seems worse only after the engine warms up. If the problem is with the speed govenor, advice on where to look for it on the engine.
Post a Followup
: Re: Farmall 200 Engine Speed
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
