Farmall Tractors Discussion Board
Re: 1945 Farmall A Governor
Posted by big fred on May 25, 1999 at 10:33:45 from (12.13.226.16):
In Reply to: 1945 Farmall A Governor posted by Mike McVey on May 25, 1999 at 09:18:03:
Shouldn't be doing that. I noticed when I disassembled the governor on my B that the sleeve that rides on the gear shaft was stuck and didn't travel on the shaft. The sleeve I am talking about is moved by the flyweights and pushes the thrust bearing which pushes on the rocker shaft, resisted by the governor spring. It's 1/2" ID, about 15/16 OD, about 1 1/4" or so long. If that is stuck, your governor is not doing anything and the weights are free to clatter like you describe.
Post a Followup
: Re: Re: 1945 Farmall A Governor
