Farmall Tractors Discussion Board
Re: Adjusting generator output on Farmall B
Posted by Jim Becker on May 28, 1999 at 19:40:42 from (209.30.183.69):
In Reply to: Adjusting generator output on Farmall B posted by Mark Selby on May 27, 1999 at 18:59:46:
The condition of the wiring and switch will affect the generator output, so I would recommend directly grounding the "F" terminal of the generator while adjusting this. With the engine reasonably warmed up and at full speed, the output should be 9 to 11 amps at 7.3 to 7.6 volts, slightly higher if cold. I would move the brush with the engine not running then start it up to check it. After getting the adjustment in range, take the jumper back off and check the output. It should still put out 9-11 in high charge and about 4 in low charge. If it doesn't, you have a problem in the wiring, switch etc.
Post a Followup
: Re: Re: Adjusting generator output on Farmall B
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
