Farmall Tractors Discussion Board
Re: fuel problem on H Farmall
Posted by RED Blooded on May 29, 1999 at 13:06:26 from (206.74.34.105):
In Reply to: fuel problem on H Farmall posted by John on May 29, 1999 at 12:14:16:
The float may be out of adjustment.But i suspect that somethig is blocking the fuel.I had a very similar problem on my I-4.Turned out a small piece of trash was stuck in the needle assembly not letting my float open right.Just goes to show that cleaning it right is important!
Post a Followup
: Re: Re: fuel problem on H Farmall
