Farmall Tractors Discussion Board
fuel problem on H Farmall
Posted by John on May 29, 1999 at 12:14:16 from (204.116.102.247):
The engine dies out because lack of fuel in
carb. no gas at drain plug on bottom of carb.
disconnected fuel line at carb. and removed
screen everything looks ok and plenty of gas
flowing thru. fuel line.
it seems as though something inside the carb.
is restricting the gas flow,any clues?
tractor will start and run until gas is gone
please help,lots of work to be done
thanks john@ tn.
Post a Followup
: Re: fuel problem on H Farmall
