Farmall Tractors Discussion Board
Re: Re: Re: Re: Where to add oil
Posted by The Red. Also Levy on May 30, 1999 at 14:12:48 from (216.192.171.81):
In Reply to: Re: Re: Re: Where to add oil posted by RKS on May 30, 1999 at 13:42:50:
There is a little square nut in the bottom of the oil filter assembly. If its not torn up, unscrew that to drain 2 or 3 tablespoons of oil before removing the cover. The big nut takes a 7/8 inch wrench on that nut.
When you change the oil filter, take the time to dig out the old rubber gasket that the can squeezes onto. A new gasket should come with your filter. You don't have to replace it each time, but the one in there may be ancient.
Post a Followup
: Re: Re: Re: Re: Re: Where to add oil
