IH-966
Posted by brazos on March 22, 2009 at 09:32:34 from (24.167.22.206):
I need help identifying and fixing a part located on left side of tractor just below battery case. It is about the size of a coke can and has linkage rods (one rod connecting to clutch). It also has 2 hydraulic lines connecting to the bottom. Has rubber boot covers on each end. Rubber boot covers are bad and oil is leaking out of end closest to clutch. Can you tell me the name of this part and if it needs some sort of kit or something to fix it?
I will appreciate anyones help.
