Re: Super MD (Pics)
Posted by D Slater on March 22, 2009 at 09:39:07 from (72.65.135.243):
In Reply to: Super MD (Pics) posted by Andrew Z on March 22, 2009 at 08:37:48:
Not a bad looking tractor. Good running SMD have pretty good power, should have as much as your M. Don't know if your gauge is good on pump. If it is and the needle goes up to operating range the filters should be okay. You should be able to idle the engine down and shut off with hand throttle. Check easy stuff first, timing, fuel flow, throttle linkage, if you have a tach is engine going to rated RPM, intake air restriction, if there's still a problem it may be the governor in pump or a sticking rack. Also could have low compression.
