Farmall Tractors Discussion Board
Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
Posted by RKS on May 31, 1999 at 14:36:36 from (152.173.21.113):
In Reply to: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1) posted by mj delaney on May 31, 1999 at 12:36:12:
MJ - you can lay hands on a timing light that just uses the spark energy for the strobe (no battery required) - and you can use a battery in a vehicle that you just park close to the tractor, like jumping the battery. Also, it really doesn't matter much, but the spark occurs as the points "open," and lose the ground for the primary winding, not as they close - which begins to charge the coil primary and the condenser. RKS
Post a Followup
: Re: Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
