Farmall Tractors Discussion Board
Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
Posted by TomH on May 31, 1999 at 15:35:10 from (206.99.145.214):
In Reply to: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1) posted by mj delaney on May 31, 1999 at 12:36:12:
I use a cheapo timing light I bought at a discount store with both 6 and 12 volt systems. Only difference is the flash isn't quite as bright on 6 volts. Use it inside and rub something white in the notches. I really couldn't hear any difference with the timing five degrees either way, but the tractor does have more power and starts easier when its exactly right (this afternoon after a few too many hours in the sun I started it in third gear with a baler and loaded wagon hitched on behind. Then I turned it off and took a break...).
Post a Followup
: Re: Re: Re: Re: Re: 3 good tune-up tips for beginners, back to back (#1)
