Farmall Tractors Discussion Board
Re: Re: Re: Oil filter
Posted by The Red on June 01, 1999 at 11:36:48 from (206.246.187.2):
In Reply to: Re: Re: Oil filter posted by Levy on June 01, 1999 at 10:59:21:
I hope your wife doesn't drag you behind the car!
Oh shoot, this is the Farmall board.
Levy, it all depends on how many hours that H has been running with detergent oil. It took my Farm H a good 250 hours to get most of the sludge cleared out.
If your pushrod chamber inspection plate is leaking (plate behind the oil filter can) I would get a gasket for it. When you have that plate off, clean out as much as the sludge that you can. That is a real collection point for sludge in this engine. On my 51 it was a good 1/4 inch thick in that chamber.
If your valve cover is leaking and you get a gasket for it, clean out the rocker arm assembly as best as you can. That is another collection area.
If you haven't been on my site, punch below and check out the 8 pages on the 51 H.
Post a Followup
: Re: Re: Re: Re: Oil filter
