Farmall Tractors Discussion Board
Re: Proper readings on a cub ammeter
Posted by Bob M on June 02, 1999 at 06:06:19 from (192.232.120.193):
In Reply to: Proper readings on a cub ammeter posted by Hugh on June 01, 1999 at 19:40:34:
Sounds like - A) Your Cub battery is hooked up negative ground (should be positive ground), and B) The generator or cutout is not working.
If everything is working correctly, with lights on ammeter should read negative amps and engine NOT running, and slightly postive amps WITH engine running full speed.
With lights off, ammeter should read somewhere around +5 to +10 amps with engine running.
Post a Followup
: Re: Re: Proper readings on a cub ammeter
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
