Farmall Tractors Discussion Board
Re: Farmall A. Got spark, got gas. Won't start.
Posted by mj delaney on June 03, 1999 at 08:08:21 from (198.167.60.43):
In Reply to: Farmall A. Got spark, got gas. Won't start. posted by Don K. on June 03, 1999 at 05:45:08:
That's what it sounds like to me. Check the point gap and mag/distributor position again. I assume the "A" has timing gears,I doubt they jumped. Also check compression. Hope it's not something more serious. You probably need spark at pretty close to TDC
Post a Followup
: Re: Re: Farmall A. Got spark, got gas. Won't start.
