Farmall Tractors Discussion Board
Re: Super A -- 12 volt system?
Posted by RKS on June 05, 1999 at 02:10:50 from (152.204.176.194):
In Reply to: Super A -- 12 volt system? posted by bronco on June 04, 1999 at 21:15:53:
battery from 6v to 12v and grounding system changed to "neg" system, that is (battery(-)post grounded to chassis) rather than the pos grounded to chassis, starter would not have been changed since the 6v starter even works better with 12v battery and reversing the grounding system doesn't make it turn the wrong way, charging appliance would have been either changed from 6v gen to 12v gen, or from gen to 12V neg ground alternator, alternator would either be internally regulated and run to the switch or required a voltage regulator also in series with the switch from the "field" clip on the alternator, head lights and any other bulbs would have been changed to 12v bulbs, ammeter would not have been changed, just leads reversed. Think that's about it. RKS
Post a Followup
: Re: Re: Super A -- 12 volt system?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
