Farmall Tractors Discussion Board
Re: Re: Re: Re: Re: Re: Re: Follow up -- got spark, got gas won't start.
Posted by RKS on June 06, 1999 at 02:55:55 from (171.211.198.92):
In Reply to: Re: Re: Re: Re: Re: Re: Follow up -- got spark, got gas won't start. posted by Larry on June 05, 1999 at 20:53:42:
Larry, not sure I follow you completely and that's fine. My only point was it seemed that if the only thing one suspected was ignition timing that was radically off, it seems so much easier to just locate TDC on #1 with compression and then route the rotor to the correct spark plug wire. If it then fires and runs, the valve issues including valve cover removal are just set aside. Cheers, RKS
Post a Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Follow up -- got spark, got gas won't start.
