water in oil in my super a
Posted by wcroom on March 22, 2009 at 17:37:22 from (64.12.116.73):
It was bound to happen... I was out dragging my pastures with my Super A this evening. My son is going to pick up where I left off tomorrow, but isn't so reliable(teenager). I checked the oil, and there"s water in it. The tractor has been using water for the last couple of years due to a leaky radiator. Apparently, some of it is going where it shouldn't. I drained a good bit into the can I cover the exhaust with, and it's just as gray and foamy as you please. I also noticed a very slight oil leak between the head and block just behind the carb. My question is this: Is there anything other than a head gasket that would cause this? Does the water in oil/ oil leak outside point towards a bad head gasket?
Somebody please tell me that"s all it is!
