Re: water in oil in my super a
Posted by Hendrik on March 23, 2009 at 01:58:48 from (194.53.253.51):
In Reply to: water in oil in my super a posted by wcroom on March 22, 2009 at 17:37:22:
It may just be a failed head gasket. My Super A also had water in the crank case oil pan, which was caused by a water leak between block and sleeve (at the bottom of the sleeve where the O-ring is).
HTH. Hendrik
