Farmall Tractors Discussion Board
Re: Govenor to carb problem
Posted by The Red on June 08, 1999 at 12:48:53 from (206.246.187.2):
In Reply to: Govenor to carb problem posted by Pee Jay on June 08, 1999 at 12:40:43:
Pee Jay, if I understand you correctly, the throttle lever won't hold a position. If you have the traditional Farmall throttle lever with the jagged tooth throttle cap, check your throttle lever itself and see it the small rise that fits into the cap indentations is badly worn.
If you have an aftermarket friction throttle, you will need to tighten the nut.
Post a Followup
: Re: Re: Govenor to carb problem
