Re: Drive your engine clean?
Posted by CNKS on March 22, 2009 at 18:40:57 from (216.144.104.128):
In Reply to: Drive your engine clean? posted by mattofvinings on March 22, 2009 at 18:14:40:
Forget the cleaner. The governor is easy to work on. Get a repair kit from Case-IH, you also need a manual to tell you what to do, or perhaps someone who types faster than I do can type it for you. Adjust the main jet on the carb to 3-3.5 turns out. Be sure the carb is absolutely clean. Max is 5, but that is for maximum load which I doubt if you need. The only gear you should have trouble starting in is 5th. You can also check the compression, but it probably has to be well below 100 to act as you are saying.
