Farmall Tractors Discussion Board
Re: Exhaust manifold tab
Posted by Curt Cooke on June 10, 1999 at 05:50:56 from (207.75.224.250):
In Reply to: Exhaust manifold tab posted by R on June 09, 1999 at 10:30:43:
R, What model tractor do you have? I don't know them all but off hand I cannot think of a Farmall tractor whose governor depended on an external spring attached to an exhaust manifold.
Post a Followup
: Re: Re: Exhaust manifold tab
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
