Farmall Tractors Discussion Board
Re: Farmall 300 shifting problem
Posted by Curt Cooke on June 11, 1999 at 06:15:11 from (207.75.224.250):
In Reply to: Farmall 300 shifting problem posted by Hickory Hills Farms on June 11, 1999 at 05:48:18:
The clutch has nothing to do with it. Two things will cure this problem. First, your shift lever is worn out on the end allowing it to move from one shift rail to another before the first one has become aligned with the second one. Next time you pull the shifter out examine the end. Building it up with weld may solve the problem, if you're lucky. The springs and balls that constitute the detents in the shift rails are probably also faulty making shifting between gears way to easy. The combination of sloppy shift rails and a worn end on the shifter lead to the problem you have.
Post a Followup
: Re: Re: Farmall 300 shifting problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
