Farmall Tractors Discussion Board
Farmall 300 shifting problem
Posted by Hickory Hills Farms on June 11, 1999 at 05:48:18 from (209.166.172.222):
I recently purchased a Farmall 300 and I am having shifting problems. The tractor will sometimes stick in two gears at one time. When this happens I have to remove the shifter and realign the shifting forks. I was told before that this problem could be solved by adjusting the clutch linkage on the side of the tractor. Should I adjust the long or short linkage? Should I make them longer or shorter?
Post a Followup
: Re: Farmall 300 shifting problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
