Farmall Tractors Discussion Board
Re: Super A clutch
Posted by Curt Cooke on June 11, 1999 at 06:20:55 from (207.75.224.250):
In Reply to: Super A clutch posted by michael 'the legend' on June 10, 1999 at 20:44:57:
The followups are good with regard to a stuck clutch disc. I would split that tractor and replace the clutch. My experience is that once a disc rusts to the pressure plate or flywheel, it's a problem that will re-occur and haunt you forever. Split it and fix it and get it over with. Good Luck.
Post a Followup
: Re: Re: Super A clutch
