Farmall Tractors Discussion Board
Super A clutch
Posted by michael 'the legend' on June 10, 1999 at 20:44:57 from (204.116.96.76):
I just bought a Super A. Something is stuck on the clutch/flywheel/something?? When the tractor is started and the transmission is in neutral, then you can not get it in gear. When you depress the clutch pedal, it seems to have no effect. You can turn the tractor off, put it in gear, start it, and it will run in that gear; then when you depress the clutch pedal, the tractor continues to run, as is the clutch has no effect. What is the problem? What is the solution? How do I keep it from happening again? Any help is greatly appreciated.
Post a Followup
: Re: Super A clutch
