Farmall Tractors Discussion Board
Re: Super A clutch
Posted by Jim Becker on June 11, 1999 at 19:26:16 from (209.30.183.252):
In Reply to: Super A clutch posted by michael 'the legend' on June 10, 1999 at 20:44:57:
Before you tear into it to fix a stuck disk, check to see if the linkage is all working. Maybe something just fell apart. Look in through the access hole on the left side while someone works the pedal. If the throwout bearing isn't moving, look for disconnected linkage.
Post a Followup
: Re: Re: Super A clutch
