Farmall Tractors Discussion Board
Re: Super M hydralic's
Posted by Bob M on June 15, 1999 at 13:42:48 from (152.170.47.59):
In Reply to: Super M hydralic's posted by Greg on June 15, 1999 at 07:25:25:
Depending on the weight of your disc/planter and the bore of your hyd cylinder, you may simply be working a beyond the capacity of the hydraulic system. The stock, engine-driven pump is rated at 1,200 psi - not exactly high pressure by today's standards. And after 45+ years of use, it is unlikely it develops full pressure anymore.
You might try a larger bore cylinder if you've got one. It'll lift slower, but it will lift more...
Post a Followup
: Re: Re: Super M hydralic's
