Farmall Tractors Discussion Board
Super A Transmission Noise
Posted by B White on June 16, 1999 at 09:51:06 from (141.218.111.60):
Thanks for the replies. The noise I refer to in my transmission is not a whine, which is present in all straight cut transmissions, but a distinct hammering noise that sounds like someone is hitting the transmission with a hammer every time a particular gear tooth comes in contact with another gear tooth. The noise in only in reverse and first gear. The local dealer said sometimes the oiler gear, which rides on the 1st reverse gear, causes noise so I removed it with no change. The common gear is the 1st-reverse speed gear, but I can't see any obvious problems with it. Any ideas would be appreciated.
Post a Followup
: Re: Super A Transmission Noise
