Farmall Tractors Discussion Board
Re: Super A Transmission Noise
Posted by Phil Auten on June 17, 1999 at 04:53:19 from (206.175.72.226):
In Reply to: Super A Transmission Noise posted by B White on June 16, 1999 at 09:51:06:
Might be a bad bearing on the 1st-reverse gear shaft. Also check shift fork for that gear for a bent finger. Try jacking up one rear wheel of the tractor and having someone turn this wheel while you watch what happens inside the trans. That might give you some better idea of what's going on in there.
Phil
Post a Followup
: Re: Re: Super A Transmission Noise
