Farmall Tractors Discussion Board
Buying Farmall H
Posted by john james on June 16, 1999 at 18:54:18 from (205.188.197.169):
MY son is 9 years old and has been saving to buy his first tractor. He is looking at a Farmall H. It has two tubes on radiator broken which will need to be repaired. Also, the oil pan has a leak where it hit something. It has jb weld on it but I can probably fix it a little better.
Otherwise, runs and starts great. It has steel spoke wheels and 90-95% rubber on rear and new front tires.
I don't know much about farmalls but probably will get to know this one well. Will he be doing ok to pick this up for $700. Also, if anyone has pulled this model, I would be interested in knowing how it does. Thanks for any help you might have
Post a Followup
: Re: Buying Farmall H
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
