The wide front makes no difference going down the furrow. The narrow front turns better on the end once you learn how to use the tractor to turn and straighten the wheels (with no power sterring). The tricycle front is less stable and more app to tip. For front mounted gangs, the trycycle front tends to bog up in sandy or soft soil worse than a wide front using more horse power for smoothing behind plowing or planting. Since we had sandy soil, we would switch out the front bolster for a Swartz wide front before using the front mounted planters on our 200. The wide front on the 200 was hard to turn and a bugger to operate.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
