What's better for plowing Wide/Narrow?
Posted by Farmall Bob on March 23, 2009 at 04:55:09 from (24.31.158.92):
Hi Farmallers,
Question: Does a tractor pull better with a wide front end or a narrow front end? Does it make any difference as with the wide front end you have one front tire in the farrow along with the one rear tire? Thanks!
Bob
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
