Re: 300 water in oil
Posted by LMack on March 23, 2009 at 08:41:31 from (98.66.239.24):
In Reply to: 300 water in oil posted by 300wb on March 23, 2009 at 07:36:49:
Since these engines are sleeved, you may be getting leakage around one of the sleeve seals. You will have to pull the oil pan and head to see if there is another crack. The other option is a head gasket problem. FYI, we had a 200 that leaked water into the oil for 20 years before my dad finally had it resleeved. It turns the oil a milky gray color and steam comes out the filler port when hot. New sleeves, pistons, and a head rebuild should cost less than $1000.00.
