Posted by 300wb on March 23, 2009 at 07:36:49 from (69.27.50.189):
Hey Everyone
Picked up a 300 row crop with fast hitch this winter for 500 dollars. Figured it had that much in parts for my other farmall tractors. Spring is here, and started messing with it the other day....found a lot of water in the oil pan. Since then....put some used oil back in the tractor...filled the radiator....and spun the engine a few times. Everyday I open the drain slightly and a little bit of water/antifreeze runs out. Any ideas where it could be coming from? Dont know much about the tractor...but was told it did run last year pulling logs....
My 2nd thought....I have a 300 utility in poor shape...thought about using parts off the row crop to get the utility running...Hyd pump...and radiator...are they the same? What parts wont interchange between the two.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
