Farmall Tractors Discussion Board
Re: Re: Re: Re: out of fluid
Posted by Levy on June 19, 1999 at 09:28:41 from (209.32.187.45):
In Reply to: Re: Re: Re: out of fluid posted by The Red again on June 19, 1999 at 06:44:46:
It's leaking on the left.... arm? If that's what you would call it. Right at the section that actually extends and retracts (the clean part).
The pan is still pulled, unfourtunatly I won't be able to get to it until next week. I ran out of light last night, and I'm an OTR truck driver leaving in 5 minutes for AL. so no hurry on the reply.
Sounds like good advice on the oil changes - I also figured I'd pull the pan again in about a year or so to see if I have any more sludge in the bottom. I don't plan to fight w/ that drain (why make myself a new problem?) it should be easy enough to siphon out w/ the side cover off. That cover is pretty crusty and I'm not sure how well it will clean up - woulden't a regular gasket be what I want on that?
thanks again
Levy
Post a Followup
: Re: Re: Re: Re: Re: out of fluid
