Farmall Tractors Discussion Board
Re: Re: Re: out of fluid
Posted by The Red again on June 19, 1999 at 06:44:46 from (216.192.165.42):
In Reply to: Re: Re: out of fluid posted by Levy on June 18, 1999 at 21:47:16:
Levy, if you still have the oil pan off, I would pull that screen assembly off, take the top protector cover off and thoroughly clean that screeen. I you are going to use detergent oil, and with that much sludge in the pan, be prepared to change both the oil and the filter about every 20 hours. Sounds like your block is really dirty.
On the hydraulic leak, where are you exactly leaking at?
Post a Followup
: Re: Re: Re: Re: out of fluid
