Farmall Tractors Discussion Board
Re: Dead spot in hand throttle, H tractor
Posted by The Red on June 23, 1999 at 07:12:04 from (206.246.187.2):
In Reply to: Dead spot in hand throttle, H tractor posted by john on June 23, 1999 at 07:00:24:
John, remove the governor plate and the spring and check the thruster and ball bearing unit. It should only slide horizontally. If the bearing cage can be wiggled from a straight vertical position, then that assembly is worn out. Ken Updike has those. 608-455-2411. If I recall its $65 give or take. You might also need to replace the spring.
Post a Followup
: Re: Re: Dead spot in hand throttle, H tractor
