Farmall Tractors Discussion Board |
Re: Hydrolics, 2 way cylinder
Posted by Stan(VA). on June 23, 1999 at 10:05:34 from (207.79.164.6):
In Reply to: Hydrolics, 2 way cylinder posted by Perry on June 23, 1999 at 08:56:37:
Yes, plumb an open center two-way valve from the current pressure port (ie: you leave the current control rod engaged all the time) and run the return to a tee fiting that you put on the reservoir filler neck. IH sold a valve that attached to the filler neck for this purpose, or any aftermarket valve would do. Stan(VA).
Post a Followup
