Farmall Tractors Discussion Board
Re: Farmall Super C Governor
Posted by big fred on June 24, 1999 at 11:05:22 from (12.13.226.16):
In Reply to: Farmall Super C Governor posted by Curt on June 23, 1999 at 18:44:42:
From your symptoms, I would guess that the thrust collar that the flyweights act against is not moving freely on its shaft, possibly due to rust build up.
I just got done with the governor on my B, which has a very similar, if not identical governor to your C. I found there was not much lubrication gets into the governor, and rust got a pretty good foothold. Check your linkages first, and if they check out, take off the governor, clean and lube the flyweights, the thrust collar, replace the thrust bearing (less than 5 bucks), check the spring (mine was rusted thru), check the rocker shaft for free operation.
Post a Followup
: Re: Re: Farmall Super C Governor
