Farmall Tractors Discussion Board
Re: Farmall M grader
Posted by Phil Auten on June 24, 1999 at 18:09:51 from (206.175.72.226):
In Reply to: Farmall M grader posted by Jeff on June 23, 1999 at 16:40:26:
Jeff,
Look on the tractor part for the casting numbers. They are raised and cast into the larger parts. They'll look something like 4-11-Q, which would be April 11, 1947. Starting in 1938 with H and ending in 1958 with D, only V was skipped and when Z was reached they started with A again. U and W were both used in 1951. Confusing, but helpful sometimes when there's no tag.
This info came from Guy Fay's Farmall Letter Series Tractor Originality Guide, an invaluable resource.
Phil
Post a Followup
: Re: Re: Farmall M grader
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
