Farmall Tractors Discussion Board
Re: Re: Farmall M grader
Posted by Jeff on June 24, 1999 at 19:20:35 from (205.188.193.188):
In Reply to: Re: Farmall M grader posted by Phil Auten on June 24, 1999 at 18:09:51:
Thanks Phil,
I went and looked at the tractor again and on the back axle I found the code 3 19 W. I take this to mean March 19th 1951. Where are other places to look for dates? Will all the parts be made in the same year? Is it safe to assume that the tractor is a 1951 model? That would have been the year it was made into a grader as well right? Once again thanks for the tip.
Jeff
Post a Followup
: Re: Re: Re: Farmall M grader
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
