Re: 300 water in oil
Posted by SDE on March 23, 2009 at 17:31:30 from (98.125.77.82):
In Reply to: 300 water in oil posted by 300wb on March 23, 2009 at 07:36:49:
This is from left field, so don't get up-set. O'Reillys has three or four different products to seal leaks. Some claim to be able to fix cracked heads or blocks. From $10 to $40 if I recall correctly. NAPA has a sealer for $1.59 that is in a small plactic container about the size of a roll of nickels.
I would retorque the head bolts then try the NAPA product first. Afterall you got it cheap enough that you can afford to try a cheap fix.
SDE
