Farmall Tractors Discussion Board
Re: Super A battery charging
Posted by J Risher on June 29, 1999 at 15:49:28 from (63.67.89.205):
In Reply to: Super A battery charging posted by Mark B. on June 29, 1999 at 06:07:57:
I would check the magneto if its still hooked up.
I've seen several switched to coil. Any how the magneto should keep it running even without a alt. or gen. When I bought my Super A it didn't even have a generator on it. I finally found a pully for the one that the man gave me with the tractor and hooked it up. There is an oiler on the magneto, if when you turn the motor over you should here the magneto click. If it doesn't, you might oil it with some light oil. The manual says sewing machine oil or "cream separator oil" .
As far as the charging is concerned, my trouble I've had, has always been in the battery cables.
Good luck, J Risher.
Post a Followup
: Re: Re: Super A battery charging
