Farmall Tractors Discussion Board
Super A battery charging
Posted by Mark B. on June 29, 1999 at 06:07:57 from (207.226.128.114):
I have a Super A that has been converted to 12 volt. It was done prior to my purchase and charged fine. Now it will not charge the battery at all, it has a new alternator and battery. I have had both checked at NAPA and their fine. Sometimes the tractor will shut down as if it's running off the battery itself, yet when I remove a battery cable with it running, the alternator seems to keep it going. Also, once when when jumping it with my truck, I set positive to the amp gauge, and it showed charge. I'm getting desperate, tired of jumper cables and shut downs. Any help would be apreciated.
Post a Followup
: Re: Super A battery charging
