Farmall Tractors Discussion Board
Re: Super A battery charging
Posted by bronco on June 29, 1999 at 18:42:32 from (206.150.163.2):
In Reply to: Super A battery charging posted by Mark B. on June 29, 1999 at 06:07:57:
I had the same problem with my SA, after alot of trouble shooting , I found the trouble in the voltage regulator, but mine was seperate!!! Could the built in regulator go bad??? But still let the alternator function? Take off the battery lead to the alternator and put a ampere gauge between the BAT terminal and the wire you just took off and start her up, that will tell you if you'r charging out of the alternator.
Post a Followup
: Re: Re: Super A battery charging
