Farmall Tractors Discussion Board
Re: Re: Super M hydraulics and oil change
Posted by Dale on June 30, 1999 at 07:14:22 from (147.225.33.25):
In Reply to: Re: Super M hydraulics and oil change posted by Phil Auten on June 30, 1999 at 06:32:56:
I got it working this morning by removing the return line from the two-way valve and adding two quarts (non-detergent) through it. Apparently a previous owner plumbed the fill hole for the return line. I will replace a elbow in it with a tee so I can fill it easily. Also, the pump is next to the distributor so the outlets by the belt pulley are not pressurized.
Thank you all for your tips!
Post a Followup
: Re: Re: Re: Super M hydraulics and oil change
