Farmall Tractors Discussion Board
Re: Super M hydraulics and oil change
Posted by Phil Auten on June 30, 1999 at 06:32:56 from (206.175.72.226):
In Reply to: Super M hydraulics and oil change posted by Dale on June 29, 1999 at 07:35:54:
Dale,
Did you use non-detergent oil in the hydraulics? If you used detergent oil, it's foaming and your hitch won't function properly. If you used non-detergent oil, try adding more until everything works properly. If it still doesen't work, you may have to troubleshoot some more to determine where the problem lies. Might just be air in the system, might need a pump rebuild. Get in there and find out. Good luck.
Phil
Post a Followup
: Re: Re: Super M hydraulics and oil change
