Farmall Tractors Discussion Board
Re: Re: Re: Super A battery charging
Posted by ltf in nc on June 30, 1999 at 08:48:43 from (206.228.213.143):
In Reply to: Re: Re: Super A battery charging posted by Mark B. on June 30, 1999 at 06:56:44:
Mark I do not beleive that it is going to charge. If you had gotten the exciter voltage to start the charging, the system would continue after the engine speed was reduced to a fast idle. I need you to tell me exactly what set up you have. Does this tractor have a distributor? Describe the Alternator. How many wires are hooked to the Alternator? Is the battery polarity neg to the ground? If you have a distributor, take the positive post from the battery while the tractor is running. Does the engine quit?
Post a Followup
: Re: Re: Re: Re: Super A battery charging
