Farmall Tractors Discussion Board
Re: Reversed Polarity
Posted by Charles Mathis on July 02, 1999 at 16:38:17 from (206.173.148.143):
In Reply to: Reversed Polarity posted by Charles Mathis on July 02, 1999 at 13:02:59:
This battery is a 6 volt battery. The coil wire goes from the positve side of coil to the points. I am to understand that all the cubs up to about 1964 were positive ground. They didn't change to a negative system until they changed to 12 volts. any help appreciated, Thanks.
Post a Followup
: Re: Re: Reversed Polarity
